Old 06 Dec 2017, 11:14 am
rob302's Avatar
rob302 rob302 is offline
Default Re: Weird Fuel Problem
there is no "real" fuel filter on these cars. they just have a sock on the fuel pump inlet. anything that gets through the sock ends up in the injectors. for what it's worth, my PT at 240,000 miles had the cleanest tank inside i'd ever seen. looking inside, you couldn't tell it apart from a brand new tank. i think with a plastic tank there just really is no need for an inline filter. the one on my mustang i can change the filter every oil change and have black crud pour out when i drain it backwards. meaning if i pour gas through it it comes out clean, if i tip it so the gas comes out the inlet, it comes out like murky pond water. i believe it is rust/metal, and the plastic tank in the PT prevents this from ever being an issue.
i believe any sediment or gunk that get through this usually sprays right through the injectors and out the tailpipe. it is possible that as the tiny debris passes through the injector it gets smashed as the injector opens and closes and accumulates over time, causing it to either spray funky, or to continue to add fuel when it should be closed/sealed since gunk is holding it open.
if injector cleaner fixes it every time, you might try to use a different gas station. everyone has their local gas station they use constantly. might be best to change where you gas up for a while to see if it prevents the problem. ...or just add the cleaner periodically
anyone else have thoughts on this?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
