Old 06 Dec 2017, 12:11 pm
myckee myckee is offline
Default Re: 2003 GT - "PT Salvage"
Originally Posted by Busted_PT View Post
First I would get a tuner device. And use your COM. Also timing belt. Like your tires time and no mileage kills rubber. The hardware should be fine. ��
The 'tuner device', like the DiabloSport, when using the 93 Octane included tune, would give him almost the same tune as the S1...to the cost of around $400 for the cheapest tuner. He already has the core pcm to use, and the S1 programming at FWD is $125. Even with the injectors, he would likely not spend much over 200 for everything.
He could still throw on a DS in the future if he decided he wanted more, and using the S1 pcm, he would have a better base to start from. The stock NGC1 pcm in the 2003 has small, low resolution maps. The NGC3 pcm that is required for the S1, has much higher resolution maps for finer and more accurate tuning. So tuning done using a DS on the S1 base would actually be better than trying to build a custom tune for the lower resolution 2003 NGC1 pcm.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
