Old 06 Dec 2017, 04:20 pm
jm4n69 jm4n69 is offline
Default Re: Things I Do When I Get Bored...
I used Sony Acid to make the music, I have several loops/beats I use for videos where I don't feel like narrating Keeps the YouTube police off my back making my own...
I couldn't find a rocker that had both ON/OFF/ON positions *and* a separate LED wiring for both hot and ground. Normally you would supply power to the center leg, which would cause the LED to switch on when the switch is on. I did mine backwards, feeding the two positions with power (accessory and B+) and used the center to feed the load (which is a USB charger shoved in the dash lol), so just having a ground lead for the light wouldn't work.
So I just drilled a tiny hole for a separate LED and it doesn't look bad... more importantly it works perfectly I can never leave well enough alone...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
