Old 06 Dec 2017, 04:37 pm
NitroPT NitroPT is offline
Default Re: Things I Do When I Get Bored...
Originally Posted by jm4n69 View Post
So I just drilled a tiny hole for a separate LED and it doesn't look bad... more importantly it works perfectly I can never leave well enough alone...
I have used K-4 for years and generally will always find what I need but like you I have had to run a separate LED light at times. On the PT Cruiser I have a red LED mounted in the upper gauge cover that lights when the radiator fan is activated either by the PCM or manual switching it on. I have it on the power side of the fan lead so that if the relay or fuse fails the light will not activate.
I even have a few of those "fat" round switches like the other guy is using for his project.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
