Old 07 Dec 2017, 02:47 pm
ptcruisersteve ptcruisersteve is offline
Default Re: Front Passenger Control arm
Originally Posted by ShaggySparx View Post
2007 Touring non-turbo automatic wagon. I'm not a mechanic but I'm good at fixing cars if i read up enough about it. I've done control arms on many cars before, but this one stumps me. I always use the Haynes manual and google/youtube. In the manual it says to remove the pencil strut and lower torque strut.
I'm gonna do it if I have to, but just to be clear...do I really have to? And if so do i have to adjust it when i reinstall it? And if so, How?
Thanks
The Factory Shop Manual says the same. Recommend you get the Factory Shop Manual so you are confident of the information you need to do the repair.
The Factory Shop Manual also gives the procedure and dimension required when making the adjustment after reinstalling the lower torque strut. This only takes 30 minutes after you have done it the first time.
Are you just replacing the bushing or the control arm?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
