Re: Would This Be A Fuse Or .... ?
Check fuse # 3 (40 amp) in the power distribution center (PDC) under the hood. It is a common feed to the fuses and circuit breaker for all three systems that you mentioned. Check the fuse first.
The Power Window Switch and the A/C Heater Control switch share the same ground circuit G203. The air bag control ground is G202.
