Old 06 Jan 2018, 01:19 pm
06_PB6_TOURING 06_PB6_TOURING is offline
Default Re: Would This Be A Fuse Or .... ?
P1XXX codes are manufacturer defined. ( RE not part of the OBD 2 standard so they vary from make to make and likely model to model. )
I'm coming up with battery disconnected in the last 50 starts ( in the 06 -10 manual )
Have you lost the setting for the digital clock ? I've seen batteries get weak enough that the cranking voltage will sag low enough to trigger an error but the car will still start and run.
The old standby was if the radio lost presets however, on my 06 the presets remain even if the battery is disconnected for weeks.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
