Old 12 Jan 2018, 11:14 pm
JoeX JoeX is offline
Default Re: 2003 touring,coolant leak under timing cover
Get it to operating temp and look closely to the air purge fitting and the base of the thermostat.
The thermostat housing is a sort of plastic and will bend or warp over time and may not be able
to hold the pressure of the system at the base where it contacts the aluminum thermostat base housing.
If either of these areas are completely dry, then I would agree with rob302
If you changed you timing belt, did you replace the water pump too?
How many miles ago?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
