Old 16 Jan 2018, 10:16 pm
ptcruisersteve ptcruisersteve is offline
Default Re: 2008 pt cruiser loss of power while operating
Originally Posted by pkelso View Post
Hi. While driving i will either lose power or the engine "chugs". If it completely looses power i can turn it back over. Sometimes it will repeat itself, other times it will be fine. There has never been an engine light. So far i have changed out the cam and crank sensors, cleaned the throttle body, checked spark plugs and wires and reset the TIMP and used injector cleaner. This has been going on for close to 1.5mnths. Does it sound like it could be electrical and if so any clue what? Thank you in advance.
Since your computer is not triggering codes I would suggest checking the ground wires going to the PCM.
