Re: 2008 pt cruiser loss of power while operating
most likely a fuel quality or delivery issue. fuel injectors, ignition coils, and spark plugs when they act up they usually commit codes.
also consider your engine light could not be working. and, some of the triggered codes could just be temporary.
did you actually plug in a scanner just after or during the trouble occurance
