  #29 (permalink)
Old 16 Jan 2004, 10:35 am
macster macster is offline
Send a message via AIM to macster
quote:Originally posted by hyracer
mcmaster,
You have e-mail.
To run my spring-mod I have a flat bracket I attached to the back of my engine block. There are a couple of threaded holes below the head that are not used...at least they are not used on a 5-spd. (use metric bolts to attach. The spring I used is a universal carb-return spring from NAPA...they run around $8.00
You can also order one from Jegs, it's a Mr. Gasket part #720-19
To attach the spring to the waste-gate arm you will need to put a very small wire hose-clamp on the arm to keep the spring from sliding up the arm. I only attach the spring when I run at a race-track because I read in the SRT4 forums that the computer will compensate for the spring over a period of time thereby netting you back to S1 HP. The spring-trick nets me two-tenths faster ET at the race track. Takes me about two mintutes to install/remove.
Deen
Thank you sir.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
