?Lines coming Loose?
I have a 2003 gt/autostik..it has a MBC, PVC-home made air-pipe to the Stock air-box, all baffles removed, K&N aircleaner, and the trick I read about on the forum here, to remove and block one of the lines (Black-Line Trick?). I use the car every day to and back from work....I don't "step-On" it every day (well-maybe..) and I do keep the boost at about 12pounds knowing that if needed I could get about 2 pounds more, with the turn of the screw. Well, one day I note that there was a loss of power..I turn the screw and no-change...Pop the hood and what do I see but the line to the BOV is off.??? I put it back on and all is OK for a day or two then it happens again...same problem, this time I use a zip-tie to hold it on. Now it is ok...Question to my teachers....Why..... PS I read this forum all the time and would like to say THANKS for all your Help!!!!!
Love the Car, Forum...and Starting to Hate the Mini, not because of the car..but the silly owners!!!Thanks agian Guys (Gals)!!!!
