The pass side facia cuts easily. I bought the cutout trims specifically because I had to cut the passenger side. There is an issue with the trims because the drivers side facia cutout is wider for the GT than the NA. If installed carefully they fit fine. I used small stainless bolts and nuts on the drivers side to attach the trim cutout. That gave me more room for adjustment and a tighter fit to the facia and it made no difference that the attaching bolts were crooked. You can't even tell. There is just 1 little spot on the right side of the cutout trimplate that shows. You have to look real close to see it. Here's a pic.....
