quote:Originally posted by IRPT
quote:Originally posted by KingKole02
CREWZIN, and Bobs Pt turbo,
Thanks for the help, I got them on. After useing some force I figured out how to take the panels off there and from the floor to access the wires need to hook up my signals. I deciede to leave the parking lights off due to a possible ticket.
Tell us what you had to do to get the panels off, just in case someone else needs that info, pics would be great.
IRPT,
So I don't have pics because I don't have a digital camera and a 35mm comes out to crappy.
Kickpanels:Start near the front by the carpet, pulled out towards the petals or dashboard (passenger side), after that you just pull the lower side the same direction and eventually it will come out. Its held in with plastic little clips that slide into plastic grip hooks in the frame.
The top clip is in at an angle and the bottom two go in straight.
Door kick guards:
Start near the front of them and pri under it with a flathead screw driver and push up. It will start to loosen. Carefully move back towards the back of the door area. This panel piece is held in with plastic clips that slide into plastic grip hooks in the frame. There are four. After it is loosened up just lift straigth up and they come out.
Mirror wire guard:
Small piece of interior in the top right or left or the door by the mirror. Get you finger or a flathead under it to pop out the metal clips and remove it.
Door panel:
Lower window.
Unscrew 3 screws around the outside of the door, one in the door handle latch release, and 2 torx 30 screws in the handle (underneath). Start nearest the mirror and slide your finger down towards the bottom part of the door gently pulling to release the plastic clips in the door. After the door is fully released, you have to pull up on door to remove it from the window track area. Once off, you must unclip the door unlock/lock wire by pushing up on the clip while pulling out, then unhooking the door hatch release bar by uncliping the yellow or blue clip that holds it in and pulling back to remove it from the hole it sets in.
Mirror:
Unhook the power mirror wires from the power mirror wire box. Just unscrew the mirror nuts on the interior side to remove the mirror by sliding it out from the door.
Thats basically it. The M3 installation is a little more involved then that for the install.
This is basically what I had to do to access the wires in the kick panel and to remove the stock mirrors.
Kick panel access is not neccessary for mirror removal.
