Thread: no start
Old 02 Feb 2019, 06:37 pm
Carl48 Carl48 is offline
Default Re: no start
Originally Posted by ptcruisersteve View Post
I would suggest a battery load test. Batteries can go bad anytime. Make sure battery cables and connections are good.
If you have a voltmeter check to see what the voltage is when starting it.
Should have mentioned... performed a battery load test, also checked specific gravity, all cells OK. All battery connections and grounds are clean.
Will check cranking voltage.
