Thread: Aoogah horn
Old 19 Aug 2004, 07:50 am
Default Aoogah horn
My aoogah horn is not cooperating. Hit the button, and it only works maybe 1 out of 15 or 20 tries. Worked fine yesterday. Every day I pass thru a tunnel under a railroad and hit it (a local custom).
With engine off, I can hear the relay click when I hit the button, so that tells me either relay contacts are dirty, I have a loose connection, or the horn is starting to go. Plan is to go direct from battery to horn to see if it's the horn, check all connections, the replace relay.
Any similar experiences? Had it in for nearly 3 years - it's "acted up" before, but very infrequently. I have the JCW "wolo" horn. Any other thoughts, recommendations? [:I]
