quote:Originally posted by IRPT
That's really interesting amx1397, thanks.
ditti!
Tell you what. I'll make you an offer as follows. After I put S2 in I'm going to the Dyno. If you want, I will do 3 pulls as follows:
S2 + K&N stock
S2 + K&N Macster MOD
S2 + your design
The deal is I will publish the results for all to see, and if yours out performs the other two, I get to buy it for 60% of your cost.
One more thing, if you change the cone on the K&N to one open ended one like you are using, the out come will change or at least be very close. I'll share a secret the open end cones open up the mid range HP and bottom end torque. So you won't be able to leave him off the line and at 20 and 60MPH like you used to.
macster
