Old 02 Sep 2020, 07:22 pm
muzicmax's Avatar
muzicmax muzicmax is offline
Question Air/fuel Gauge Question
I have a 2003 Gt. I want to install a A/F gauge. I went to the Glowshift site on how to install. It says:
Air / Fuel Ratio: Connect the green wire to the vehicle oxygen sensor signal, before the catalytic convertor. You may connect this
wire directly to the ECU harness or splice into the signal wire
leaving the sensor. This wire color can vary, be sure to consult your
vehicle’s owner’s manual. (0v ~ 1v Output - NARROW BAND
ONLY)
Am in the category NARROW BAND ?
I don't have a catalytic converter. I have a Catless 3 " downpipe.
I'll admit I'm not good with this kind of stuff....
I just want to hook up to the signal wire or the oxygen sensor wire i'm not going to attempt hooking it up ecu harness so that's out of the question
Is there something I can tap into on the fuse box inside the car or in the fuse box under the hood?
Any help would be appreciated!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
