quote:Originally posted by Punch
Beacon: what size is your sig, mine is a bit small!!!
Mine's 500 pixels wide, 100 pixels tall.
Looks like you noodled it through but the easiest way to merge the pics together is to resize them to the dimension you want, copy them (CTRL+C) then paste them into your sig image as a new layer (CTRL+L). Then you can use the Move tool to shift it around to where you want. Once you've got everything where you want them you can either merge them all together by going to the top line menu and selecting Layers>Merge>Merge All (Flatten Image). Though you don't really have to do that as it will automatically merge then when you save it out as a .jpg/.gif/.png. You can also use the 'Run Optimizer' option if you want to compress the image a bit.
I'm using 1600x1200 as well and the hp/tq text is a bit small but I can still read it.
