Old 29 Jan 2004, 07:24 pm
Cal Cruzer Cal Cruzer is offline
quote:Originally posted by turbomangt
[Engine Gunk is fine for heavy grease build up, but instead of spraying it off, use a damp rag by hand. You are better off changing buckets of water more often and using more rags.
That stuff is really bad. I sprayed a degreaser on my engine once. As I was hosing it off I realized that it was petroleum based and it was all running down the storm drain. At that point there wasn't much I could do but the storm drain eventually empties out into the bay by my house. I felt like a gross polluter watching it all go down the drain. My engine really wasn't that dirty since I clean it regularly with Simple Green. I thought this stuff was something similar to that. I would avoid Gunk and others like it if possible. Stick with the Simple Green or Orange Citrus cleaners. They do a great job.
