Thread: stuck throttle
Old 02 Feb 2004, 06:56 pm
LAF LAF is offline
Punch,
Glad you made it.
Do you think it was an ice condition? I mean I hydra mine in 10-15 degree temps but never in the engine bay directly, do wheel wells, under carriage, spare wheel and the car, use the soft "gray" water rinse at the end, never had this problem. I also donÂ’t use my emergency brake in this slush either for fear of it freezing in the on position.
Did or could you post any links on the SRT-4 dudes having this same issue?
Man you are right, it takes a lot in a panic situation to maintain your thoughts.
I think I read somwhere for the Dakota recall.
This is kinda scary stuff. Dont want to be "chicken little" but did you call anyone? Just would want to get it on a service record. I am just wondering where the cable would freeze if that was the problem.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
