Old 04 Feb 2004, 02:54 am
MichaelDay MichaelDay is offline
quote:Originally posted by 2coolPT
I tow my 2002 PT Limited 5-speed behing my motorhome with all four wheels on the ground. Someone told me that I can disable the odometer from racking up miles when towing by removing a fuse. Does anyone know which fuse?
No need to remove any fuses. The PT's will not register mileage when towed four down unless you have the engine running. Just turn the key to the first position to unlock the wheels, release the e-brake, put the little puppy in neutral and enjoy. I suggest that you put diodes in the wires that you are tapping into for the lights from the motorhome. You may occasionally find that if you have run the engine, shut it down and immediately start towing your PT that you may add 0.1-0.2 miles. This only happens occasionally and I have never seen it accumulate more than 0.2 miles even if it is towed hundreds of miles. I suspect that the computer is just checking to be sure you aren't "cheating" by shutting down the engine and coasting down hills to reduce the mileage.
Enjoy your PT is makes a great toad.
