Old 08 Feb 2004, 04:08 pm
scottmech scottmech is offline
Sorry for not getting back to answer the questions quickly.
This dp should work with any aftermarket system that has a similar bottle neck (2.25 stock dp to 2.5) as the Borla. Need to verfy it though.
I picked the Mopar because it's a popular cat back.
The dp in developmant will go from the O2 housing to the end of the stock cat. All you will have to do is cut off the bottle neck in the Borla (hack saw will work fine) and install the dp.
It will be avail in aluminized or stainless, with or without cat, and extra O2 bungs if needed.
Any yes I'm still running the automatic dual stage boost controller. Dynoed at 267 hp and 304 tq with it 2 weeks ago. Mods are the above mentioned boost controller set to 18 psi, agp wga, IPP intake, my O2 housing and 3 inch turbo back, no other tuning.
