the diameter of tires (of the same numerical size) can vary amongst the various tire manufacturers. check the diameter of the tires that came with your car with the tires that you want to put on your pt now. the tire rack is a good source of information on line, or call tire stores that carry your original tires and get the dimensions from them. compare that spec with what you want to buy, and you'll be in good shape for making your decision. changing the diameter will affect the speedometer and if you get different diameter tires between the front and the rear, that will affect your anti lock brakes. let us know what you end up buying and how they are working for you.
redrum
03 gt
