Old 10 Feb 2004, 06:37 pm
IRPT IRPT is offline
quote:Originally posted by KingKole02
Is disconnecting the negative battery terminal necessary for replacement of radio? It mentions this in the ptdiy.net guide.
KingKole02, I think every repair in the service manual recommends disconnecting the negative battery cable.
From the service manual:
Radio
REMOVAL
(1) Disconnect and isolate the battery negative cable.
(2) Remove instrument panel center bezel.
(3) Remove mounting fasteners and remove radio
from instrument panel
(4) Disconnect wire harness connector from radio.
CAUTION: Pulling the antenna cable straight out of
the radio without pulling on the locking antenna
connector could damage the cable or radio.
(5) Disconnect the antenna cable by pulling the locking
antenna connector away from the radio (Fig. 7).
2002 Inferno Red PT Limited
Mercedes Wiki
