Floor Jack Points on PT
I know the points that Chrysler says for hoisting the Pt...Ther is a diagram inside the passenger side door. But looking at the four areas they reccomend it seems that the flat area metal is very thin. when you tap it with your fingers there does not seem to be any reenforced metal just this sheet metal...also no rubber pad for it...like my caravan has. I dont want to damage the PT with a floor jack. Can you please tell me where you are lifing your PT at. I do have the Rhino Ramps but I need to rotate the tires so I have to lift it off the ground. Thanks for all of your help....
