Old 20 Feb 2004, 12:42 pm
amx1397 amx1397 is offline
to do this drill about 3/4" deep with a drill set up for the tap size you want either 1/8 or 1/4. with your hole about 3/4" deep take a 1/8" drill and angle it to the inside of the manifold. now drill your small hole for the boost and vaccum to go to, then use a pipe tap and tap the hole for your fitting, done.(this needs to be done off the car and make sure you get the drill fillings out of the intake manifold.
jim
