Save your money on the ignition stuff and go directly to Stage 1. You won't find a better bang for the buck. It lists for around $400 but can be purchased in the low $300's. Some on this site are even reporting more MPG after the install. A Stage 1 car will blow the doors off your stock Turbo and ignition upgrade
Deen
