Old 22 Feb 2004, 03:03 pm
ptgtcb ptgtcb is offline
I would install the amx1397 turbo to air box pipe and remove the silencers. Add a 3" CAT/ down pipe assembly into the stock exhaust with a BTG straight through muffler or BTG duels. I would also recommend a boost gauge. This will set the stage for SII.
Then patiently wait for STAGE II!
While your waiting for stage II lower it and put some bars on it.
Then consider a stoptech brake upgrade kit.
If you can not wait for SII get an mbc or ebc +/or SI and add a DSABC. It would be nice if we had an adj. WGA available as this would really help with SI and a mbc/ebc. scottmech is getting 267hp and 304ftlbs on his sr-4 with this set up, but, he is using a agp adj. WGA.
Just some thoughts.
