Old 26 Feb 2004, 06:02 pm
amx1397 amx1397 is offline
I am running 18lbs of boost and here is where i am connected and beleave me the amx1397 intake does work,
1. at the wastegate there is a orange or brown vac line ( looking over the engine at the turbo) disconnect that line and put the mbc in line." note" (if you have no control) it is backwards, it must be almost closed to up the boost, the boost gauge can be almost anyplace on the intake manifold a port of it's own would be the best. to go over 14 lbs of boost without getting the p1188 ,,just before your throttle body, on the hadr plastic part of the host to the throttle body, there are two connections one elect, and the other is boost pressure to your pcu,, disconnect that rubber lind cap off the niple and just lay the 1/8 plastic hose wherever you want . now go play.....and then tell me the amx1397 intake does not work( maybe you are not paying it enough.
jim
