OK at mid throttle your boost goes up to high, , i just tried that and mine too I have NEVER driven at 1/2 throttle before it was wot or nothing, I see that if you cruise at 40 mph and ease up to like 60 the boost goes way up so to correct this either punch it and then let off or ease down on the throttle for 20 or so seconds and then let off, but when i go wot my boost goes to 18 and stays until it shifts(auto) then drops to about 15 then climes back to 18 and repetes on each gear, when cold it is more . turn yours down about 4 clicks, try not to go above 20 lbs of boost. where is your boost connected, if you are on the tip niple you will read more boost because of the rubber hose expanding, do you have a vacuum/boost guage or just boost., also turn your mbc around from what you are sayinf it may be in backwards, when you have it off blow on it you will blow freely one way and very little the other, that way you know it is working, also if you pinch off the line it will give you full boost, and you may be doing that(your mbc may be closed,and you eng boost works with throttle position. I think maybe you better call me because i just read what i though i said and i hav confussed myself..954 336 3405
jim
