Old 28 Feb 2004, 05:25 am
Jason_L Jason_L is offline
If you use a fuel piggy back (like the greddy eManage), you can tune/adjust the injector duty cycle to compensate for bigger injector, higher pressure, additional sub-injectors, etc.. they alter the MAP sensor signal sent to the PCM to "trick" it into doing your bidding
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
