Old 04 Mar 2004, 09:10 am
IRPT IRPT is offline
IGNITION COIL
REMOVAL - 2.4L TURBO
(1) Disconnect the negative battery cable.
(2) Remove the throttle control shield.
(3) Remove the throttle cables from the throttle
body lever.
(4) Remove the throttle cable bracket and relocate.
(5) Remove the spark plug cables from the ignition coil.
(6) Unlock and disconnect the electrical connector
(7) Remove bolts from ignition coil. Twist coil to
remove 2 of the boltsfrom the coil before removing it from
vehicle.
(8) Pull coil up and out by the throttle body side of the intake
manifold.
INSTALLATION - 2.4L TURBO
(1) Install the coil on throttle body side of the
intake manifold, rotate down past the throttle
body to the valve cover.
(2) Connect and lock the electrical connector to the ignition coil.
(3) Install bolts to ignition coil. Twist coil to install 2 of the
bolts to the coil after installing it to vehicle.
(4) Install the spark plug cables to the ignition coil.
(5) Install the throttle cable bracket.
(6) Install the throttle cables to the throttle body lever.
(7) Install the throttle control shield.
(8) Connect the negative battery cable.
NOTE: Check and make sure that throttle body and
attachments will not contact ignition cables.
2002 Inferno Red PT Limited
Mercedes Wiki
