Old 05 Mar 2004, 06:35 pm
amx1397 amx1397 is offline
ok, my non turbo, stock ran 18.55 in 1/4 then the only mod was installing the 2" tubing from the hole next to the fog lite to the top of the fender well where the intake gets it't air. I then ran 18.24 in the 1/4 two different Sundays temp about the same 85* no aftermarket intake no nothing. on my turbo the intake and the hose in the fenderwell was installed at the same time when the car was new. so i believe that every little bit helps, the hose may give me 2 hp the smoothing out intake gives me 11 hp so now i have 13 extra hp, I'll take all i can get. just to show you what i mean go to the track or wherever you like to go fast and make a run. we all do it from point a to point b we go 90 mph or whatever we do now remove your rear seats go do it again you will go faster this time, I always make sure i have 1/4 tank of gas when doing a test that way i am always the same weight., inflate your tires to 65 lbs is good for .03 in the 1/4 mile et and about 3 mph. try it you will like it.
jim
