Ian thank you I do hope every understands what you have said.
1. the smoother the pipe the better the air and increase power and mpg.
2. the plastic pipe, 2 1/4" will give you cooler air,
3. the 3" metal pipe being smoother gives you more air, which means the turbo doesn't have to work as hard to get air to it,and so much goes through it that it is cooler than the 2 1/4 plastic.
3. this allows the turbo to spool faster, and produce more power for less work.,
4. as shown by LAF doing this 3 to 4 times a week, from point "a" to point "b" 100 mph, after adding the amx1397 intake down pipe made the same run 3 or 4 times a week he now goes 110 from point "a" to point "b". wot the intire way but 10mph more Huh something works
5.what works, works, some like, some don"t, some own it, some don"t
again thanks Ian I think you put it in a way that shows everyone that a CAI does work some better than others.
6. and mine is the best.
jim
