Old 09 Apr 2003, 11:22 am
skylight's Avatar
skylight skylight is offline
Administrator
Default Recall: some 5-speed Turbos
Recall / 2003 PT Turbo:
DC has determined that a welded pin internal to the dual-mass flywheel (DMF) assembly can unseat and become lodged between the flywheel and the clutch disc. If this occurs, the clutch may not disengage when the clutch pedal is depressed. Local dealers will replace the flywheel and clutch assemblies with the updated design parts. Recall date: March 4, 2003.
Model affected: 2003 PT Cruiser Turbo (manual transmission models only) manufactured from October 14, 2002 through November 29, 2002. Potential number of units affected: 816.
If you haven't received a recall notice and think your vehicle may be affected contact your local DC dealer, or call the DC Customer Service Assistance Center at 1-800-853-1403. Have your VIN number available when you call. DC notification number: C09
More info at http://www.ptdoityourself.net/pttsb.html
__
Jody
03 Steel Blue GT Loaded Autostick
- weatherstrip-less
- airbox silencers removed
- Revell shift knob
> my pics
