Old 09 Mar 2004, 12:26 pm
Dragula Dragula is offline
That's interesting. Usually when you tighten up the rear of a car it tends to oversteer (loose) instead of understeer (push). I'd like to know if anyone else had that effect because I was thinking of just adding the stock rear stabilizer bar as well.
Maybe that's why Eibach went with a smaller front bar than stock. That would loosen the front end adding a bit more more bite. It's all about balance.
I would also think that if you installed the strut bar you would tighten up the front end causing more push.
Black 03 PT Turbo & Black 94 Impala SS
