Old 14 Mar 2004, 06:26 pm
Ant Ant is offline
That is the cat back tubing & cat, no muffler. They have mufflers avail, but I chose my own.
I fabricated my own 3" DP and tack welded it, brought it to an exhaust shop and had him TIG it.
After installing DP, BTW this is a perfect time to add an extra bung for your WIDEBAND 02 sensor, I took it to the same Ex. shop and he fabbed the DP to the cat and hung the exhaust. I was able to stay and help him the whole time. We put in some flanges so I can drop sections of the exhaust easily for later work.[8)]
If you have 3" custom pipes made for you, let him (I think it is Jason or Justin I worked with)know I (Anthony)referred you after the work he did for me. That might put some aded pressure on him for a perfect product again!!
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
