Old 14 Mar 2004, 10:40 pm
CREWZIN CREWZIN is offline
First of all...the diffusers worked! I know this is hard to see but it's the glow from the lights showing the rear and drivers side of the car inside my garage.
Turbo Jim. Yes it's probably something that you yourself can do but I paid to have it done. Cost me $75. I did some of the wiring myself by taking off the center console and adding the lighted on/off switch and running the wires so the shop could just attach the computer control right up to it. Neons are a lot easier as they hook up to each other and you only have one wire. The Plasmaglow each have their own wire that has to run up front and attached to a block and then the block has a ribbon type of wire that has to run to the computer control. The lighted switch runs to both the computer and the fuse block.
I DO NOT intend to run these light anywhere except at a show or parade so I'm not worried about legalities. They won't be on when I'm driving.
