REF - younotintopunctuation LOL
I don't want to make any statements that Scott at Maxxfab has to back up, but this is my opinion: I believe his PT downpipe will work for any PT 2.5" cat-back system. It should be long enough, because it's actually longer than the stock PT downpipe to eliminate the 2.25" transition in the cat-back part. Just make sure there's not some extra long 2.25" transition in the Trubenz - like more than 3 inches. I needed to cut 4 inches off the Borla for perfect fit. You also need to confirm whether the outside diameter of the Trubenz system is the same as the Borla. I believe that the pipe diameter is expressed in outside diameter measurements - so I think Scott's downpipe would work on any 2.5" OD cat-back system (again my opinion). It is plug and play for the PT, but of course you still need to cut off the cat-back system to remove the 2.25" transition.
