PTGT, I have the Keystone dual scoop Good Hood, I am using the Airaid ram air box, and the AMX turbo 3" up pipe to airbox setup. I love it. believe it or not the turbo does spool up quicker. It seems to be quicker. I have a turboXS dual stage boost controller as well. I use a momentary actuation switch on the (autostick) shifter (hurst roll control switch) for easy & quick access. I also have the "lock On" jet fighter switch mounted in the center console between the Trac Off and the Rear Defrost switch. You'll love the Ram Air setup. Damn this car is fun to drive....
