quote:Originally posted by JohnM
REF - I looked at the picture of the Trubendz system again after you pointed out that there was a resonator behind the cat in their system. I don't think that Scottmech's downpipe will work with this system because the resonator is immediately behind the 2.25" transition section. In other words there is no 2.5" pipe before the resonator to connect with the 2.5" part of the downpipe.
Not true. The inlet is 2.5" they supply a flange to adapt to 2.25 or 2.5. FYI the resonator center core is 2.5". It also appears they will build you a custom system as you like.
