Old 23 Mar 2004, 09:00 am
Ian-PT-GT Ian-PT-GT is offline
quote:Originally posted by Reed
The error codes I get do not appear an any list I have been able to find. I get the following 3 codes:
FL 0007
EE 10
6L 01 or bL 01
Can anyone out there tell me what they mean?
My Engine lite keeps will be on for week then off for a while, and the on again.I notice some stumbling at idle.I have verified these codes 5 or 6 times.
Those are not the codes.
That is the information from the PCM when it does a self test or an Information Cluster Pannel self test.
This shows up when you press the odometer button and turn the ignition key to on at the same time.
The numbers you got most likely where followed by all the dash lights iluminating and then all the gauges moving all the way to max in 25% intervals.
For you to get the codes, you need to turn the key three times to on consecutively without actualy starting the car.
Ian
