Thread: Turn signal
Old 28 Mar 2004, 01:22 am
Based on what I see on the road, seems only you and me use turn signals![)]
Sounds like the flasher relay ( a little black plastic cube in fuse panel) may be going. 4-ways use different contacts, and since bulbs light, can't be bulbs. Maybe with lights on, the relay isn't "seeing" enough voltage.
Another thought - might be bulb after all. When filament in bulb breaks, sometimes the 2 ends touch and it'll light, then they separate, and it won't light.
