Old 30 Mar 2004, 11:30 am
alceryes alceryes is offline
quote:Originally posted by Mean Green
That chip is not for turbos and I wouldn't want it. Dealer flashes your pcm and you lose it all. Stage 1 may or may not cause warranty issues. Depends on the dealer. My dealer said if Stage 1 causes a problem my warranty could be affected. He said my warranty is not voided just because I have Stage 1. Some dealers will void your warranty for any mod. Luckily mine won't. Go here for Stage 1 info.
http://www.mopar.com/pt_stage_1.htm
For an '04 it just considts of a new pcm, but same price as an '03.
An '03 turbo is rated at 215 hp, but it is more like 220 hp. So stage 1 should take you to 240 hp plus your mods. An '04 is rated at 220 hp because it already has the stage 1 injectors and with stage 1 is rated at 240 hp.
Since it's just a PCM replacement it's an easy job right? Do you have any website that details the PCM replacement (with pictures)? As far as the warranty goes you could just switch back to the stock PCM and reset the computer if you needed to bring it in and they shouldn't be able to tell, right?
