A friend and I installed rear swaybars on our GT's. Instead of using the oem bolt that holds the bar to the rear axle, use a 2" long stud, 3/8 dia.( its about .020 smaller the the oem bolt) and put the back nut on the stud and then inserting the bolt thru the bushing bracket and then put the outside nut on. Works slick, and if you have a hard time holding the nut inside the bracket that hold the assembly to the axle, the 2" in stud is long enough to put a pair of vice grips on the tip of the stud to hold while tighting the nut.
