Old 28 Jan 2005, 10:18 pm
otrqt otrqt is offline
Default squeaking...."bushing" problem??
I took my 2002 PT to the dealer again today to see about a squeaking/rubbing noise that sounds like it's coming from the front driverside wheel. I just had it in 9 days ago for replaceing the power steering pump, power steering gear assembly, steering oil cooler equipped, solenoid assembly-transaxle, solenoid valve body, thermostat and gasket and coolant.
The service manager said he "guessed" it might be a "bushing".
What is that and do you think that would be covered under my extended warranty (Limited power train/ certified maximum car are the plan codes for the ext. warranty 8yr/80K)
Thanks
Ronda
