Thread: Dyno numbers
Old 02 Apr 2004, 11:50 am
Ant Ant is offline
Wow! Something is very wrong, you are dangerously LEAN!
What exactly does the AFR graph look like?
What RPM are you hitting that 17.5:1? Through the full range or at redline?
Is it possible the wideband is faulty or wasn't hooked up correctly.
What is your boost spiking to? You should be seeing 10:1-12.5:1 depending on certain variables.
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
