quote:Originally posted by paulkopick
This has the upgraded pcm that came with stage1. What is a safe a/f ratio on the gt compared to our17.5???Thanks all for the input.
When you installed the Stage I PCM, did you install the Stage I Injectors?
If you don't install the larger injectors, which are standard on the 04 cars, then this might explain the extremely lean AF ratio.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
