Thread: FACTORY STEREO
Old 04 Apr 2004, 02:47 pm
ElectricBlueGT ElectricBlueGT is offline
RODRUN,
If you buy an amplifier that has current sensing on the inputs (RCA or speaker level), you won't need a remote turn-on lead. For example, JL Audio sells amplifiers which have this feature. There are many other manufacturers that have this amp feature.
Tapping into your speaker wires as a signal source is not bad as many think it is. The typical headunit speaker signal is 15-20 volts but low current. If the headunit doesn't produce alternator whine through the speakers now, the amplifier shouldn't also (presuming good grounds, nothing pinched, etc [common sense items]). Did you upgrade your rear factory speakers yet? If you did, did you use the speaker harness adapters? If yes, tap off the adapters for signal to the amp.
Scott
\"If you choose not to decide, you still have made a choice.\"
